best clutch for my setup?
Old Nov 30, 2002 | 01:43 PM
pirate3's Avatar
Default best clutch for my setup?
I need some reccomendations on which level clutch to go with. I am going with the RAM because I have a wholesale account with SUMMIT. I am looking at the 600 or 900 series. I am currently putting down 355/371 w/bolt-ons and will be adding a moser 12 bolt w/4.10's and a healthy split/reverse duration cam very soon. I should be putting down 415/430. I need a clutch that will hold up to daily driving and 6k rpm launches on et streets. Thanks in advance for any suggestions!
Check out www.ragingmotorsports.com
<small>[ November 30, 2002, 01:44 PM: Message edited by: elraksaz ]</small>
Old Nov 30, 2002 | 09:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: best clutch for my setup?
RAM 900 series disk will do (910).Also you will need to run the RAM billet flywheel.
Old Nov 30, 2002 | 11:16 PM
Brother J's Avatar
I'll second the recommendation for the Ram 900 series.
Old Nov 30, 2002 | 11:46 PM
LS1PWR02SS's Avatar
ram is a excelent choice. they hold up pretty well on both street and strip.
Old Dec 4, 2002 | 12:37 AM
CaptainSS's Avatar
First hand exp. Fantastic clutch!
