trans swap
Old Aug 24, 2007 | 06:17 PM
mattz28zx6r's Avatar
Default need help with trans swap
I have 2001 camaro with a 4L60E and I want to put a T56 in it. what all do I need as far as electrical
Old Aug 25, 2007 | 08:12 AM
ChevyThunder17's Avatar
You can rewire the harness for the reverse lockout and the backup lights, not terribly difficult. Alternatively, you could buy an M6 harness but they aren't easy to find.
Old Aug 25, 2007 | 09:42 PM
formulamd's Avatar
You tap into your center consol wiring harness for the reverse lights, electric hatch if equipped and clutch switch (to start the car). The speed sensor has the same connector as your auto, but you need to extend your wires. I believe the reverse lock out needs to be tapped all the way back the computer. But im not sure.
