Shifting problems.. Replaced everything.
I've noticed my problem actually goes away if I force it in.. like, if it goes in a gear, any gear, it goes in all of the other ones fine. But once the clutch comes out, its back to square one.
When you park the car do you leave it in gear? Is it 1st gear? Is your line from the master to the slave heat wrapped?
I was having a issue myself with the 1st gear being hard to get into. For some reason if i leave the car in neutral when i park it, it doesnt do it as much. Now the other thing i noticed is if it is hard to put into gear i just wiggle the stick a little in neutral and then it will pop right in. Just some ideas.
Oh, and shim is installed (I think).... I installed a ring in between the release cylinder and clutch that came with the Spec
