ls7 clutch
Old Aug 27, 2007 | 08:12 PM
kps's Avatar
kps
Question ls7 clutch
I have a gm pn 24238412 new in box .Have ls2 flywheel .when I rest clutch disc and pressure plate on flywheel the gap between the 2 mating surfaces(pressure plate and flywheel) is.625. now way in hell this is going to work.The two dowel pins in flywheel arent even close to being able to help with alignment because they are too far away,the pressure plate bolts wont even reach the flywheel to begin to tighten down.what gives?
