Operating temperature for T56... (Cooling system?)
Just an idea... It's not like there's a lot of slippage in the manual enough to cause a heat issue like in an A4....
I was thinking of the supply line being from the drain plug, to a pump then to a cooler mounted in front of the radiator, then the return line going into the fill plug on the trans.
I know my trans gets warm, but not hot enough to require a cooler.
