Lightest M6 flywheel???
TIA
3:90/4:10 gears will really suit the lighter flywheel.
For drag racing the best 60' time will be achieved with a heavier flywheel setup. They are also easier to drive.... however if you can't figure that it needs a little more gas from the get go.... then you should be driving an automatic anyway.
BTW- There are some 9 second drag racers on here with aluminum flywheels. They just make lots of power and their 60' time won't get affected much at all.
