flywheel
Old Sep 4, 2007 | 08:42 PM
FL Junkie's Avatar
Default flywheel
how is a ls1 flywheel balanced does it have a harmonic balancer? i thought it was just a steel flywheel. the reason i ask is im about to buy a clutch the stock one is clunking when i shift. some other tech at work is telling me an ls1 flywheel has rubber in it for harmonic balancing. and if thats what causing my problem i will have to get a new flywheel too.
any input on that?
ive never done a clutch swap on my car or an ls1. i was just gonna replace the clutch and resurface the flywheel....
