Cartek or Mcleod
Old Dec 6, 2002 | 03:32 AM
DONAIMIAN's Avatar
Default Cartek or Mcleod
Witch one would be a better buy and I need some feed back on both clutches, how much can the cartek clutch hold, im jsut confused can someone pleas hel me out here <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
EDIT: On cartek site it also says I cant use poly trans mounts, is the true for the Mcleod too.
<small>[ December 06, 2002, 03:35 AM: Message edited by: stang killer ]</small>
Old Dec 6, 2002 | 03:57 AM
JackZ28's Avatar
Default Re: Cartek or Mcleod
I have the Cartek with the steel billet flywheel from SLP. This clutch can handle anything I throw at it, so I highly recommend it.
Old Dec 6, 2002 | 07:54 AM
Gimp98TNT's Avatar
My cartek clutch has performed very well, but it all depends how much power your putting down. Mine is just now starting to slip, and I'm putting about 550rwtq to the ground, and i'm sure the 6200rpm launches on the spray didn't help it much.
P.S. it had about 8K miles and 125 passes on it. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Dec 6, 2002 | 10:57 PM
John B's Avatar
Moderator
Just installed my Cartek and am VERY pleased with the smoothness at takeoff (without any chattering) and firm grip between gears <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 9, 2002 | 10:56 PM
2002_TAWS6's Avatar
hmmm from what I read on other posts most people chose mcleod over cartek? People stated that mcleod is better for street use and cartek does a lot of chattering after been used for a few months time? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> somethings wrong here...
