Clutch Fluid
Old Sep 26, 2007 | 09:20 AM
DTB_LS1's Avatar
Default Clutch Fluid
I recently flushed my clutch fluid in my 2000 SS w/42,000 miles on it fallowing Ranger's guide. After flushing about 10 time the fluid became clear again. I then took the car for a ride, and when I came back and checked it the fluid was black again. I repeated the steps and flushed it another 10-15 time, took the car for a ride again, and when I came back the fluid was black again. In all I've flushed it about 20-25 times. My question is, should I just keep flushing until it comes clean or are the seals in the system going bad?
Old Sep 26, 2007 | 12:23 PM
Bad Blue WS6's Avatar
same boat,,just did this last weekend, with the same results....
Old Sep 26, 2007 | 01:28 PM
matt3383's Avatar
There are only 2 things that i know will turn the fluid black. Boiing the oil, or the seals in the master and or slave are going out and turn the fluid black.
Old Sep 26, 2007 | 02:06 PM
DTB_LS1's Avatar
So what you are saying is that you think the seals are going bad. The fluid was fresh and I only drove about 5 miles each time before rechecking it. Or could it be that I didn't pump the clutch pedal fast enough or flush enough times to aggitate all the gunk and sediment that was in the system.
Old Sep 26, 2007 | 05:15 PM
DTB_LS1's Avatar
Any other opinions??? I'm planning on getting an LS7 clutch and new hydraulics this winter but I'm also going to the track before the end of the year and I'd like to figure this out before I go.
