issue with reverse
Old Oct 9, 2007 | 06:41 PM
yaco7usa's Avatar
Default issue with reverse
It's hard as hell to put the reverse in my T-56 I already check master n' slave cylinders, fluid level and the clutch itself, evrything looks ok but i need to pull/push really hard to get on reverse. Anybody knows here what should be the problem??????????/
Old Oct 9, 2007 | 07:01 PM
NJgunslinger's Avatar
Try putting it in Reverse with the key turned on but the car turned off. If it goes right in, then it is definitely a clutch or Hydralics problem.
Old Oct 10, 2007 | 06:45 AM
calhoon's Avatar
Thats just oposite and wrong advice.The reverese solenoid requires powering to open the gate. It should get reverse easily with the key on/ engine off. Check your fuses and wiring to the solenoid.
Old Oct 11, 2007 | 05:38 PM
Fb0dy0nly's Avatar
reverse lock out fuse.....change it!
Old Oct 11, 2007 | 06:45 PM
yaco7usa's Avatar
Default fixed!!!
Thanks guys problem it's over
