Need help
Old Oct 31, 2007 | 06:21 PM
m1candelaa1's Avatar
Default Need help
I just did a clutch swap but i cant seem to get any presure in my pedal it feels real spongy.I tried bleeding it several times but it still feels the same,any help???
Old Oct 31, 2007 | 07:05 PM
mrhzk35404's Avatar
Mity Vac
Old Oct 31, 2007 | 07:35 PM
camaroguy26's Avatar
I agree. I give props to those guys who can bleed the clutch by the book, I can't even hardly get a damn socket on the bleed screw. a local parts store has the mity vac you can buy or rent, if you try searching on here you should find a writeup
edit: here ya go https://ls1tech.com/forums/showthrea...light=mity+vac
Old Oct 31, 2007 | 08:36 PM
awh that is so f*cked up,i just cut my floor board by the gas pedal to access the blled screw.I hope that mighty vac works i'll pick one up tomorrow.
Old Nov 1, 2007 | 06:05 AM
67pete's Avatar
From what I've read, it takes at least a quart of fluid to flush out all of the air, using the gravity method!
It is a very messy job....I rigged up a small diameter hose to fit inside the bleader valve, connected to a smaller diameter brake line tube that extends down to a container. Over the clear hose I put the long, 12mm, socket and then whatched the bubbles coming out of the slave through the clear hose. When the bubbles slowed down, I went a pushed the clutch pedal in to move the air still left in the system. Keep repeating....Top off the master cylinder every so often.
Old Nov 1, 2007 | 03:10 PM
I tried using the mighty vac and it still does not work. Could my slave cylinder line be bad? I think its leaking cause when i hook up the vac at 12 PSI it starts to loose presure.What do you think?
