Where is my reverse switch?
Old Nov 5, 2007 | 06:36 PM
Bruser's LS1's Avatar
Default Where is my reverse switch?
Since I've had my car I have never had reverse lights. The guy I bought the car from had a new clutch put in before I bought it from him. I think the shop that did it never connected something. Any input would help. I know the the housing for the bulb does not get power when the trans in reverse. Thanks!
Old Nov 5, 2007 | 08:52 PM
wrencher's Avatar
wrencher
The switch is mounted aproximatly mid-trans on the passenger side.
Old Nov 6, 2007 | 11:47 PM
Can I get to it without hanging the car on the or in the air?
Old Nov 6, 2007 | 11:53 PM
djsanchez2's Avatar
Yeah you should be able to reach it by lifting the car with a floor jack.
Old Nov 7, 2007 | 01:21 AM
daniel6718's Avatar
yep its on pasenger side half way...i have a brand new one sittin here bruiser...call me if you need...i bet its simply cut or broken somewhere in the car...you did check both bulbs right?
Old Nov 7, 2007 | 12:25 PM
Yeah check voltage to the bulb and there is none. I think either it's not hooked up or maybe a wire is cut somewhere
