Anyone need a scattershield?
Are these available ? how much ? Are these a direct swap for the stock bellhousing ?
And more importantly....if there is a steel plate that bolts to the block first. Will it work with the ExoSkel clutches ? The cap screw heads on the rear side of the flywheel do protrude quite a bit. I cant see a steel pate fitting onto the block first ???
