Re: what clutch?
RAM 402 pressure plate and a 910 disk will serve you best. I personally have a 402 with a 6130 disk and I love it, but some have had some problems with the 6130 disk. RAM offers their clutch kit in a complete set-up called VDS. The VDS includes: pressure plate, disk, billet flywheel, adjustable master cylinder, and new slave. Its highly recommended that you get a billet flywheel because the aggressive disk will chew up the stock one or aluminum one. Stay away from Centerforce and in my opinion STAR/SPEC. Centerforce should be called CENTERCRAP!!! SPEC/STAR has a hit/miss history. Several guys have/had it without any problems but even more guys DID have problems. I hear their new clutch is a bit better. The old design used the OEM pressure plate just painted yellow and didn't offer enough clamping pressure. CARTEK clutch had a good past history but it seems many are having problems with it also. I would say go with RAM, if not because of the great product, but the GREAT customer service!!!! RAM backs their products better then anyone! CARTEK,SPEC/STAR,MCLEOD..have customer service that leaves A LOT to be desired. AGAIN do yourself a favor and go with a RAM VDS system and do it right the 1st time.
