changing clutch disk
Old Nov 10, 2007 | 07:22 PM
III's Avatar
III
Default changing clutch disk
i have spec 4 clutch 3800lb pressure plate and flywheel and it is slipping i was wondering if i can change the disk from the 4 to a 3+ without changing the whole setup.
jim
Old Nov 10, 2007 | 07:56 PM
MeentSS02's Avatar
Kleeborp the Moderator™
As long as you turn the flywheel, you should be able to.
