mccloed master "WON'T" bleed???
Old Nov 28, 2007 | 06:36 PM
weaponZ's Avatar
Default mccloed master "WON'T" bleed???
Ok i been messing with this since last week.I've searched,read and done everything i could.
I'm bench bleeding the mccloed master and it wont bleed.I've tried every angle option and even a mity vac.It wont suck fluid in and it wont release fluid out the check valve.
The master came out a buddys wrecked SS and was fine before.I dont think it was damaged in the wreck.
what now?
Old Nov 28, 2007 | 06:42 PM
brad8266's Avatar
Get a stocker and make it adjustable.
Old Nov 29, 2007 | 08:03 AM
Taspeed's Avatar
do you have a slave line attached?
Old Nov 29, 2007 | 09:39 AM
TARZAN's Avatar
Mine always seemed to bleed best if I adjusted the master cylinder all the way in, bled in.....and after I was done bleeding, I'd adjust it back to where I wanted it.
-Will
Old Dec 2, 2007 | 01:06 AM
67RSCamaroVette's Avatar
i had that problem, it turned out to be that the piston didnt come far enough back. do what tarzan said, pulling the pedal towards you to make sure the fluid reaches the orifice for the reservoir.
