Clutch Slipping?
What cinched it for me was when I wanted to overtake a car off a light due to my lane ending and giving it a good amount of gas amounted to no significant acceleration or wheel spin.
It never did fail the 6th gear WOT test or 5th gear for that matter. Where basically you go like 30mph in 6th then floor it or similarly in 5th, slow speed go WOT etc.
Put car in 4th going about 45 mph. Press the brake enough to slow down a bit, while holding down the brake a bit press the gas to the floor. Increase brake pressure immediately enough to hold the car at a constant speed (45-50 mph). Watch your tach and speedo. If your RPM goes up then your clutch is slipping. If the car bogs and you are able to decrease your RPM's with increasing brake pedal pressure and the gas still to the floor then your clutch is ok.
