'93 swap?
Also, with a 93 you may have to get a dakota digital box to get the speedo correct. The six speed has less teeth on the reluctor for the speed sensor, and I'm not sure how much a custom chip can compensate without having the car on the dyno to compare speeds.
The speedo can't be programmed for gear ratio changes easily in the older cars with chips like the newer stuff.
