Spec clutch flywheel
Old Jan 23, 2003 | 07:23 PM
BigD'sZ's Avatar
Default Spec clutch flywheel
Spec clutches tech guy says their flywheel is nodular steel instead of billet steel what's the difference? Also it weighs the same as the OEM flywheel, for another $100 they will sell you a pressure plate and flywheel that is 6 pounds lighter is it worth the money, or is the integrity of the flywheel and PP being compromised?
Old Jan 24, 2003 | 06:50 AM
Stick only's Avatar
Default Re: Spec clutch flywheel
Nodular iron is *explosion resistant*. Most pressure rings in new clutches are nodular, but as we've seen in some previous posts they still can break. Billet steel, on the other hand, is much stronger and typically used in competition components. I'd be concerned mainly with operating RPM - if you spin it hard and launch it at the track, billet is better.
Old Jan 25, 2003 | 04:56 PM
BigD'sZ's Avatar
TTT come on guys, what is this nodular iron {steel}, vs billet steel vs OEM cast iron?
