one question on my t56
Old Feb 1, 2003 | 08:30 AM
ssdungeon's Avatar
Default one question on my t56
My clutch is the z06 clutch and its fine. Just had another rebuild (syncros) and it is doing the same thing. It drives just fine but that pedal will not come up when I race. I know to look out for this so I wont speed shift.
Questions:
1> If I replace the Master and Slave would that fix the problem. My clutch looks brand new the last two times it was built so If I dont have to I dont wanna replace it.
2> Exactly what do I need to order to bolt up to my factory parts...
3> Where do I get the parts.
please list any part numbers and prices if possible.
Basically if I can get the pedal to jump out like it does in my Honda (no jokes please) I would be fine for now.
Thanks,
Old Feb 1, 2003 | 08:35 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: one question on my t56
Did you pressure bleed the master assembly before installing it? Make sure you get all of the air out of it.
Move the braided stainless line as far away from the exhaust as possible. When it gets hot, the fluid viscocity changes and sometimes makes the pedal mushy.
Do the line drill mod ASAP. Works wonders.
-Tony
