engine to bellhousing plate?
Old Jan 20, 2008 | 05:52 PM
EAMartin's Avatar
Default engine to bellhousing plate?
Do any of the LS engine installations use a plate between the engine and bellhousing to cover the front of the flywheel? If there is such a thing I need one for a custom installation I am doing. I could make one, but why re-invent the wheel if one is already available.
Old Jan 20, 2008 | 06:06 PM
DONAIMIAN's Avatar
Only time Ive seen something similar is with the McLeod scattershield.
Old Jan 20, 2008 | 08:25 PM
EAMartin's Avatar
What does GM use to cover the front of the flywheel? I haven't had the opportunity to see any factory installations yet.
Old Jan 20, 2008 | 08:38 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
There was nothing covering mine
