FINALLY....clutch is bled
Old Jul 8, 2003 | 11:30 PM
theblur98ss's Avatar
Default FINALLY....clutch is bled
Well after fighting with my clutch for 2 days and posting on here I finally got my clutch bled. I took off my mcloed adj master and used buschman's method and it worked like a charm. After getting the master back out I see why bench bleeding is the only way to go. For anyone that will be doing this install in the future....go get a mity vac right from the start. That little tool works wonders on our hydraulics. Thanks to all who helped me.
Old Jul 9, 2003 | 07:12 AM
Scalpel's Avatar
Default Re: FINALLY....clutch is bled
How do you use the Mity Vac to do this properly? Thanks man!
Old Jul 9, 2003 | 10:26 PM
http://www.phpinc.biz/clutchbleed.html. I used this write up. I didn't have the 'slave shim' so I just went to part #3. I took off the reservoir and hooked up a clear piece of hose between the reserviour hose and reservoir so I could see the air. I'd pump the vac up and watch the air get pulled up. After I got all the big bubbles out I would release the vacuum and do it again. Each time it would pull more air out. I'd let it sit a few minutes then I would shake or rotate the master a little bit and some more trapped air would come out. I tried to get the reservoir up higher so the air would naturally travel up to it.
Old Jul 10, 2003 | 12:22 PM
35th SS's Avatar
hows your pedal pressure feel?big difference huh!mine engages pppretty close to halfway of the pedal.Ilike it.
