Stock Shifter??..
Old Jan 28, 2008 | 04:03 PM
LS1Silverado05's Avatar
Default Stock Shifter??..
Does anyone have a picture of what the "stock" shifter looks like? (the working parts below the boot) Non-Hurst or Hurst??...I was told that stock shifters are held down only by two bolts....Mine is held down by four, and has a thick shift rod, metal spacer to the base, so no sound deadening, but the base looks stamped, not billet or anything. The shift ball is plain black. I think maybe its not stock, but rather a cheapo short stick?..
Old Jan 28, 2008 | 04:52 PM
jmm98LS1's Avatar
All t56 shifters are held down with 4 bolts. Here's what a factory Hurst shifter looks like.
A stock shifter's base is a similar color, but is stamped. Both the stock and factory Hurst use the same rubber dampened stick. Sounds like you've got a stock non-hurst shifter.
Old Jan 28, 2008 | 11:48 PM
I agree...but it must be an aftermarket short stick or something. Its litteraly a thick metal stick with a slight bend toward the dash, anda 1/2" thick steel spacer between the stick base and the handle.. Probably junk no matter how you cut it... A hurst will be in my future
