How do you bleed clutch
Old Jul 11, 2003 | 04:46 AM
20ramair00's Avatar
Default How do you bleed clutch
I have a 00 WS6 and just replaced clutch for first time. when I craked it I put it in 1 gear and the tires were spinning with clutch to the floor. Friends said bleed the clutch. Is that the problem?
Old Jul 11, 2003 | 09:34 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: How do you bleed clutch
sometimes you can get it to work properly by just pumping the pedal about 100 times, it should start to get stiffer as you go. This is assuming that you didn't drain out your slave cylinder in the tranny when you did the clutch swap. That would be about the only reason to require bleeding it.
Tony
