Clutch problems
Are you grinding gears when you release the clutch? The car's transmision under warranty? If it is just take it in and be done with it, if not I would start by changing the ATF fluid in the transmision (REDLINE ATF.
I had difficulty putting the car into reverse and when I changed the oil it just glided into reverse.
Sometime the oil gets dirty and it makes shifts a little tougher.
