Anything else to look at?...
At WOT I sometimes get the dead clutch pedal and I will only have a couple inches of pressure at the bottom of the pedal. Sometimes it happens on the 2-3 and sometimes on the 3-4. I have found that it will happen the worst if I am going from a roll and my rpms are up for a few seconds before nailing it. seems that the harder I am on it, the better it is..if that makes any sense?...But sometimes it hangs up no matter what. Ill be pissed if I drive to the track only to get 2 gears!
-New Master Cylinder (made adjustable)
-New Slave Cylinder
-Very well bled, including mity-vac
-Standard type LS6 clutch (good wear)
-New Flywheel
-Drill Mod
-Drives me crazy and I dont know if there is anything else I can do...
Maybe some more info on self adjusting pressure plates?...
Any helpful ideas?...
