Simple LS7 Clutch Question
Will the clutch hold well and last?
EDIT: I have a 12-bolt, as well.
a) the C6 Z06 is RATED 505, but puts down about 430-450 at the wheels in stock form
b) the C6 Z06 weighs about 400 pounds less than my car and wasn't necessarily designed as a drag strip car.
Yes it is lighter and yes its not really a drag car, but it is meant for road racing. With all the up shifting and down shifting involved in a road race, don't you think that LS7 clutch could take a beating?
Anyone have more experience with this? I may end up having to man up to a Textralia if I can't get some good feedback, and that's obviously more than double the price, which I don't really have right now.
I don't get it. If you can afford
a)$400 driveshaft (PST is the bare minimum for a power DS)
b)a beefed GTO transmission T-56 are NOT cheap (rebuild for power alone is 1K)
c)mods to bring you to 400HP (cam/heads, all bolt ons etc)
d)supporting suspension (torque arm, panhard, lca, lca relocation, shocks, swaybar etc)
How is a $1000 clutch out of range in retrospect to all those other mods, it's a drop in the bucket compared to the rear?
I've spent all of my money on this car trying to get it beefed up and capable of handling hard launches and hard driving, but now that everything is good to go, I've found that I have clutch issues that I can't seem to get rid of. At this point, it's not disengaging at high RPM even though I've replaced EVERY part of the clutch/tranny assembly, including using an adjustable master cylinder, a regular GM master, two different Spec clutches, two different GM slaves, a new pilot bearing, a new shifter, and a new tranny. All professionally installed and always using the shim.
The only constant with all of the things I've tried is that I have been using Spec clutches the whole time, so I'm scrapping them and trying something different. I'm going to replace the clutch, flywheel, and slave now since the master is brand new (just installed about two weeks ago) and I'm still having the issue. I actually have a new slave installed, as well, but I've heard that some dealers are selling the wrong slave, so I'm hoping that's not the issue, but I'm going to replace it along with the new clutch just in case. Everything was professionally installed, it just doesn't seem to go away and I don't want to destroy my brand new tranny. I'm going with the Textralia.
