Problem finding correct pilot BUSHING
Old Mar 10, 2008 | 12:59 PM
lilbuddy1587's Avatar
Default Problem finding correct pilot BUSHING
Hi all,
I'm having a hard time sliding the trans back into place. I was told by Amber @ Six Speed Inc. to replace my pilot bearing with a pilot bushing from a 69 Camaro with a 4spd Muncie trans. Problem is, when I try to look it up through the local parts stores they want me to specifiy the engine. Now I understand that the Muncie was offered with a variety of different motors, both SBC and BBC.
Which one is going to work for me? Obviously not the BBC BUT I can't find what I need when using the 350 and 302...
Please help, anyone who has replaced their pilot bearing for a bushing, which part number did you use and which parts store? Nappa/vatozone/checker?
Thanks!
Old Mar 10, 2008 | 01:07 PM
thesource's Avatar
That pilot bushing fits all SBC engines with a GM input shaft .
Old Mar 10, 2008 | 02:38 PM
bump
Old Mar 10, 2008 | 04:01 PM
thesource's Avatar
Originally Posted by lilbuddy1587
bump
Did I say something funny ?
Old Mar 10, 2008 | 05:22 PM
meandmyls1's Avatar
And the same bushing fits all Mark IV big blocks.
Old Mar 10, 2008 | 05:24 PM
thesource's Avatar
I thought so but was not 100% sure on that so I didn't say it but thanks .
Old Mar 10, 2008 | 06:23 PM
Jonathan@Tick's Avatar
LS1TECH Sponsor
Dorman pn: 690-014
This is the number I use if a customer requests a bushing instead of a bearing. I get them from Car Quest.
Old Mar 10, 2008 | 08:06 PM
thesource's Avatar
The only real advantage I've ever seen from using a bronze bushing over a roller bearing is the bushing tends to wear before the tip of the input shaft does . In a roller bearing application , the input usually goes down when the bearing does . Typically a roller bearing will last 3-4 times longer than a bronze one will .
Old Mar 10, 2008 | 10:45 PM
Thank you, I did not respond because I was busy at work. Didn't really have a lot of time to mess around.
No sir, I appreciate what you said. Thanks for the info. Now if only I can get a part number.
I can't say if I agree or disagree? This will be my first pilot bushing as I've replaced 3 or 4 roller bearings so far.
Not only that but the fact that I always seem to have
trouble getting the input shaft to slide in.
I can get it lined up no problem but it always sticks a little. There is enough room to get some bolts started but thats a big no no IMHO.
So I was told by Amber @ Six Speed Inc. that it would help the input shaft slide in easier AND offer superior longevity.
Old Mar 10, 2008 | 11:25 PM
Originally Posted by Jonathan@Tick
Dorman pn: 690-014
Thanks for the pn sir.
Old Mar 11, 2008 | 09:53 AM
thesource's Avatar
Well the roller bearing will last longer in your application if you go with an OEM version . These China made bearings you get at Vato Zone are crap . The reason GM and others went away from the bronze bushing is because they do not last as long . Back in the 60-70's most vehicles did not make it to 100K on factory parts . Now days cars are designed to go longer before they need to be worked on (in most cases) . The roller bearing offers a longer life span but causes more damage when it goes down . As for the trans going in easier with a bronze bearing , thats mainly because its a softer metal and even if its not spot on , you can drag the input shaft through it and slightly dig out some material on your way in . Is that a good thing ??? You tell me .....
Old Mar 12, 2008 | 02:07 AM
ChiTownHustler's Avatar
BCA PB-656 or PB-656-HD
