bad clutch??
Old Mar 20, 2008 | 07:44 PM
thebart455's Avatar
Default bad clutch??
hey guys just had a problem with my tranny, i have aready had the t-56 built so i know its not that but when i am driving down the highway i noticed that 6th gear if i gave it alot of throttle it slipped as well as 5th, now whats weird is i slowed the car down and tried to make sure it was slipping by romping on it in 1st and 2nd and the car pulled. what would cause this please help
Old Mar 20, 2008 | 08:32 PM
Cocheese's Avatar
I've been having the same issue. I first noticed it when i would do a little romping, and when i made the shift to third it would slip. It gradually got worse in the higher gears, and now i can only give it minimal gas in 5th and 6th due to slippage. First still pulls ok, but is starting to slip. I've also noticed that it seems like the clutch is grabbing at the top of the pedal, sometimes feels like it is still engaged (or disengaged, whichever occurs when you release the pedal).
Maybe someone will chime in that has had this issue...
Old Mar 20, 2008 | 08:42 PM
gold98Z28's Avatar
bart you just need a driver mod......and this guy's^^^^^^ sig quote caused his.
but seriously it is the clutch going out. its typical for them to slip in higher gears first then get worse.
Old Mar 20, 2008 | 09:09 PM
CW00BlackTA's Avatar
Yep, signs that your clutch is going.
