Problem With Reverse
Old Jul 26, 2003 | 05:08 PM
Cam SS's Avatar
Default Problem With Reverse
I just started having this problem with reverse with my manual trans. After the car seems to be running for a while and I put it in reverse I get this wicked vibrating noise coming from the rear of the car. I have been under the car many times to see if anything is loose, but everything seems to be O.K.. I was wondering if anyone else has had this problem or could give any clues as to what to do with it. Other than that there have been no problems with it at all. The car is still under warranty but I really don't want to take it there if I don't have to. Any help, opinions, or comments would be greatly appreciated.
Old Jul 29, 2003 | 11:28 PM
2001CamaroGuy's Avatar
Default Re: Problem With Reverse
noise or actual vibration?
Old Aug 3, 2003 | 11:02 AM
Cam SS's Avatar
It is a noise that is coming from under the car towards the left side, it sounds like something is vibrating but I don't think that anything is. It only happens after the car has been running for a little while, it does it worse when I turn the wheels when it is idling, and even worse when I put the car in reverse. I am totally cunfused now.
