Clutch Fluid and Bleeding Process
After bleeding it the first time I said screw lying on my back. I center punched the trans tunnel directly across from the 7/16 bleed valve. Pulled back the carpet inside and drilled a 1" hole thru the trans tunnel. Now bleeding is a one man job. When done plug the hole with a 1" rubber plug available at Lowes or Home Depot.
