Rear Engine Humming...?
99 LS1, 6spd stick
228 cam, AFR 205 heads
weiand aluminum intake manifold
LT's, ORY
DFX Centorforce clutch disk
I can only hear it when stopped, and ideling... whether the clutch is in or out, in gear or out of gear it doesn't matter (well, i shouldn't say in gear i guess... but at that point i can't hear it if i'm driving), it's still there... I can actually lightly feel a vibration in the clutch pedal that is in conjunction with the humming noise... it's an extremely light vibration but enough to barely feel on the clutch pedal...
but this noise just recently started, and it's been popping out of gear for a couple months now... I just have to make extra sure that it's all the way in gear before I let out on the clutch pedal...
I will say, that in the last day or so, when feathering out and taking off in 1st gear (not going fast or anything) i'll hear a squeal type of noise that again sounds like it's coming from the clutch area...
I just wonder if the constant humming, and all these other issues are related, and hopefully not engine related...
