Problems Clutch Or Bad Adjustment
Such F-Brothers. Well thought solve this problem but has become more difficult. It turns out that my
TA M6 started giving me problems in the Clutch Pedal, when he was oppressing had no pressure and failed to function properly, indicating a piston master cylinder and damaged. In parallel carriage swept the clutch (preasure plates etc.). Walk lost strength as it accelerated and was not moving. In order yesterday he changed the master cylinder, with a new one and improving the pedal, but were still sweeping the clutch. It is worth mentioning that earlier last Saturday he dropped the tranny for this reason and the only thing I notice is that the press was not rectified and was crystallized, as it preasure the plate were well and generally throughout the clutch. We brush the press. Also the mechanic who is fixed, although not an expert if it is very trustworthy. What could it be? Poor Purge cylinders master and slave? What discs are wrong? What can I do? Do
