problem with t-56!!
Old Mar 13, 2003 | 12:09 AM
Red02LS1's Avatar
Default problem with t-56!!
All of the sudden the shifter has about an inch of play front to back in every gear, and its not a cracked plastic cup where the end of the shifter sits. And gradually, there is a howling noise comming from the transmission in every gear when you let off the gas. It almost sounds like a bad rear end, but is comming from the tranny. It shifts fine though. I'm wondering what this might be?
Old Mar 17, 2003 | 10:57 AM
Red02LS1's Avatar
Default Re: problem with t-56!!
ttt...help!!
