Clutch going soon, have a few questions
Old Aug 1, 2003 | 03:04 AM
Blk98Bird's Avatar
Default Clutch going soon, have a few questions
I plan on making around 380-400 horses through my 4.10 geared m6 with a 224 cam and boltons, and possibly spraying a 100 shot dry on top. My stock clutch is going however so I think it would be best to replace this first before everything else. My question, is a new flywheel, master, and slave all necessary? I want to pick up a ram clutch and was wondering if the pressure plate and 900 series disk would be enough, or if these items were really needed? If they are, why? My car is a 98 t/a if that helps at all.
Thanks, i'm a transmission newb
Old Aug 1, 2003 | 06:35 AM
LOnSLO's Avatar
Default Re: Clutch going soon, have a few questions
You will need a new updated slave, and an adjustable master. Other than that, the pressure plate and disk is all you need.
