Symptoms of a bad master?
Old Apr 17, 2008 | 10:47 PM
Luna's Avatar
Default Symptoms of a bad master?
What are the symptoms of a bad master ? I just put everything back together. The only part of the hydros that isn't new is the master.
The clutch is disengaging all the way on the floor. Car won't go into first unless the pedal is forcefully mashed to the floor and doesn't seem to disengage properly when driving either...
Could this be a bad master or maybe still some air in the hydraulics ??
Old Apr 18, 2008 | 07:51 PM
Luna's Avatar
don't everyone answer at once.
Old Apr 18, 2008 | 08:54 PM
Soul Crusher's Avatar
does the car have normal peddle pressure?
Old Apr 18, 2008 | 10:07 PM
Luna's Avatar
Well considering I am doing a swap from an auto I'm really not sure what "normal" is but it feels fairly stiff.
Old Apr 18, 2008 | 11:04 PM
jmm98LS1's Avatar
Have you put a mity vac to the system yet? Best way I know to ensure there's absolutely no air in the system.
Old Apr 18, 2008 | 11:54 PM
Luna's Avatar
No mity vac yet. Where can I get one ?
Old Apr 19, 2008 | 05:38 AM
Jasey's Avatar
Northern Tool For $39.99, I'm having the same exact problem as you. Haven't used the mighty vac yet but I'm about to find out if it works later today.
Old Apr 19, 2008 | 06:26 AM
Slowhawk's Avatar
LS1Tech Sponsor
Alot of times with the LS7 clutch it will grab right off the floor at first,then after a few miles you wear down the high spot's in the clutch and the engagement moves up a bit.
Old Apr 19, 2008 | 09:08 AM
Luna's Avatar
Maybe I'll just try to drive it a bit more. The clutch couldn't have more than 10 miles on it right now.
Old Apr 19, 2008 | 10:27 AM
ski23's Avatar
You defintely need to bleed it better. I have about 1000 miles on my ls7 setup and had no issues with going into any gear. I bought my mity vac from autozone for around $30 and it works perfect. Just remember DONT (they say not to) go over 15-20 vac or you will destroy your seals.
Old Apr 19, 2008 | 01:00 PM
xxrillixx's Avatar
+1 for bleeding it more.
Make sure you pump the hell out of the clutch pedal. Its not like bleeding the brakes where its a nice easy push. Youll want to get down there with your hand and push and pull it pretty much as hard as you can.
Old Apr 19, 2008 | 05:11 PM
Luna's Avatar
I'll definetly pick up a Mity Vac tomorrow and give it a shot.
Old Apr 20, 2008 | 11:32 PM
Luna's Avatar
Picked up a Mity Vac today. I'll give it a shot tomorrow and let you all know how it goes!
Old Apr 22, 2008 | 07:32 AM
Luna's Avatar
Bled it again today with the Mity Vac and the old fashion way. Also put about another 30 miles on it and the engagement point did move way up. I think I'm all set now
Old Apr 22, 2008 | 12:27 PM
Mart00SS's Avatar
hows that mighty vac work, pulls a vacuum on the system and boils the air out??
