LT1 T56 Bbody problem
I just got my stock motor back in my car and been running it a few days. Well i noticed the other day if i get on it hard in 1st and then go to hit 2nd the clutch gets really soft but it'll make the shift, and if i stay in it to go to 3rd it's even worse but will grind into 3rd, but then it wouldn't go into 4th, had to pump it back up.
It never did this at all with my h/c 355, shifted fine, had a lot of pressure. And it seems to do it worse if lay in it hard in 1st and it spins up pretty fast, it'll make the shift to 2nd but no luck with 3rd. Also i was going like 10 in 2nd gear and went WOT and kept tryin to feel the clutch as the rpms climbed and it seemed to get softer and softer throughout the RPMs. Now i'm sure it's gotta be something with the hydraulics. There was a little bit of debree in my fluid as well, so could this be something a simple fluid change could fix??
My $.02 is your hydraulics may need replacing.
BBHP or F2B set up?
stock hydraulics or McLeod?
