T56 help
If the problem was there before the clutch install, you're probably in need of a rebuild. If that's the case, nobody will be able to give you anything more than a ballpark figure on cost, as it depends on what parts are worn and needs replaced......could be anywhere from $150 to $700 just for parts, then tack ~$250-300 on for labor if you're not rebuilding it yourself.
With out it extra wear on the trans & crappy shifts are the result.
How does the pedal feel? Have you ever bled/flushed the clutch fluid? Does it grab at all with the pedal depressed & the RPM brought up?
Does it engage right off the floor or close to it?
I would do the drill mod & bleed it out real good. You might need to put some hydraulic parts in there though.
