spec stage 3 replacement disc
Old May 9, 2008 | 07:08 AM
slowbrakiller's Avatar
Default spec stage 3 replacement disc
who sells them? i saw them on a sponsor's website the other day and now i cant find it. anybody know?
Old May 9, 2008 | 08:56 AM
2000NavyZ's Avatar
contact spec-01 he should be able to tell you
Old May 9, 2008 | 09:55 AM
blu98ta's Avatar
You have to call Spec directly. Stage 3 is SCD-093. I just had to order one too. I'll PM you their number.
Old May 9, 2008 | 10:36 AM
linegtdt52's Avatar
did any of you guys through your installation of the spec stage 3 clutch, need an adjustable master cylinder? I am going to do the drill mod but just wanted to double check and see how you guys were fairing out on this issue. I am replacing my flywheel with a new one so I dont think I am going to need it but that's why I am asking
Old May 9, 2008 | 10:38 AM
raiderchad's Avatar
Default Grabbing point
Was your disk worn down quite a bit. I think mine is because the guy at spec said the clutch should start grabbing about half way up from the floor. Mine is 3/4's on the way up or more. Have you guys had similar problems??
Old May 9, 2008 | 10:39 AM
SPEC-01's Avatar
Discs are typically not advertised seperately but they are available. Most dealers will have discs drop shipped from us. Pricing on a disc is typically 50% of the cost of a kit. Let me know if you have any further questions. Thanks!
Old May 9, 2008 | 04:23 PM
order placed
thanks
