do i got a clutch problem or a trans mount problem?
on take off from 1st gear, i get extreme amounts of vibration/chatter (clarify the difference) if i try to slip it. if i rev to 1500rpms and let the clutch out, i get some chatter.
when i installed the new trans mount, i didnt use a torque wrech, i just put all the bolts on pretty tight. would that affect anything?
could it be engine mounts possibly?
i know its an aftermarket clutch, but i thought stage 1 slipped like stock. i dont want to keep reving to 1500 to put it into gear because i dont want my clutch to wear out fast, but on the other hand i cant deal with all the chatter/vibration. i plan on swapping my oem mount back in tommorrow to see if the poly material mount; the oem still looks fine. all and any help will be appreciated!!
clutch.
Something else in your diag, can you tell/see if the new mount is thicker
than the stock one? You may have driveline angle issues that are exasperated by the new mount. Get an angle finder and check the Driveshaft and pinion angles.
