Guys PLEASE help!
Old Aug 18, 2003 | 11:18 PM
LASTLS1's Avatar
6 Second Club Moderator
Default Guys PLEASE help!
I have a 2002 with a spec stage three second one with in 1000 miles. It slips in between shifts, then grabs. Yes there are mods. I'm under the hp rating for the clutch. As soon as you touch the clutch pedel the clutch disenguages. Spec has no idea. Shiming seems to be wrong. I don't think the clutch should start to disenguage as soon as you touch it? Please any help. Everyone I talk to has no idea. It's not a track only car. Not alot of abuse. HELP!!
Old Aug 19, 2003 | 02:25 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Guys PLEASE help!
Do you have an adjustable master cylinder? If not, definitely get one. Sounds like your engagement point is wrong and your pedal is too high.
That partial slipping can also occur if you have a contaminated disk (oil, etc.. on the surface).
Tony
