output seal
Old Aug 20, 2003 | 08:19 AM
v8maro's Avatar
Default output seal
Got an oil change on my car yesterday, said the output seal on the trans where it connects to the DS is leaking, how hard of a fix is this? How much am I looking at? Can I do this myself? (pretty technically inclined, did H/C swap). Have any part numbers I will need?
Thanks a ton!
-Steve
Old Aug 20, 2003 | 09:28 PM
v8maro's Avatar
Default Re: output seal
ttt
Old Aug 21, 2003 | 08:27 AM
Formula 1's Avatar
Call D&D Performance 248-735-6220
They carry all of the T56 parts
Their part # is BB34 for the output shaft seal at a cost of $10.
You could also pick that seal up at any GM Dealer
Old Aug 21, 2003 | 08:56 AM
v8maro's Avatar
how hard of an install is it?
thanks for the info!
-Steve
Old Aug 21, 2003 | 03:11 PM
JeffT's Avatar
get the car up on jack stands or ramps, pull the driveshaft, use a seal puller or you might be able to get it out with a hammer and screwdriver, clean the surface, tap the new one in with the hammer and put the driveshaft back in.
