Mcleod RST twin disk clutch (my review)
About to pull the trigger on the rst, should i replace anything else while i have it apart? The car has 80k miles with 409whp with goals of 700whp in the near future. Master/slave cylinder, throw out bearing??
It's always a good idea to replace the slave while you have access to it, I would also suggest a tick speed bleeder line if you don't already have one.
Here you go: https://www.rockauto.com/en/moreinfo...nid=521&jpid=2
https://www.rockauto.com/en/moreinfo...nid=522&jpid=2
Drill out your clutch line and add a speed bleeder, should be good to go.
