Hydrolics problem??
Old Aug 21, 2003 | 06:55 PM
Ghost SS's Avatar
Default Hydrolics problem??
I have a Cartek clutch with their adj. master cylinder and their slave cylinder. I noticed that when I am racing, mostly on the bottle, that the release point of the clutch is closer(just about right on) the floor. If I drive "normally" for a while the release point will go back to the usual spot...towards the top of the pedal release. Any ideas what it could be?
Old Aug 21, 2003 | 10:40 PM
felton316's Avatar
Default Re: Hydrolics problem??
See if the hydraulic line is running close to the exhaust. You may be heating it up while racing. I seen some guys at the track come back with the pedal stuck on the floor until it cooled off.
Old Aug 23, 2003 | 04:56 AM
Ghost SS's Avatar
Any other ideas?
Old Aug 23, 2003 | 06:46 PM
2001CamaroGuy's Avatar
I second that....it sounds like the fluid is getting hot and boiling. What fluid are you using?
Old Aug 24, 2003 | 02:11 AM
YOOFORMULA's Avatar
Sounds like fluid cooking. Did you do the drill mod? Might want to also try wrapping the line with header tape if it continues to heat the fluid.
Old Aug 24, 2003 | 09:02 AM
Country Boy's Avatar
Senior Member
I have the same problem with mine since day 1 I am using DOT 5 and have the line covered with that heat sheilding stuff, so I know its not getting hot. DOT 5 has a higher boiling point that 3 or 4. It comes with the dot 5 also
Old Aug 29, 2003 | 11:55 AM
Ghost SS's Avatar
I fixed my problem!!!!!
https://ls1tech.com/threads/showflat...31&fpart=1
