Strange Noise!!!!!!
Old Aug 24, 2003 | 02:57 AM
Onyx Z's Avatar
Default Strange Noise!!!!!!
When my clutch is about half way down to the floor, a strange grinding like noise is coming from either the tranny or the clutch only when the car is moving. The pilot bearing rattles, so I know that is shot. Then the other night on the freeway cruising about 75-80 MPH, I put the tranny in neutral and coast a little ways and it won't go back into any gear. Is the clutch just getting hot or what. It works fine now except for the grinding noise mentioned up top. The entire drivetrain has about 90,000 miles on it, but the weird thing is this all happened on the same night. Until then, it worked like a charm.
Thanks
Ryan
Old Aug 24, 2003 | 08:14 AM
SilverTxT/A's Avatar
Default Re: Strange Noise!!!!!!
I had a similar problem. My car would grind @ about 4k rpm+. If your pilot bearing is shot (like mine was @ 90k mi.) then excessive vibration and a weak clutch or worn clutch adds insult to injury compounding the problem. Just change the clutch and pilot bearing and throw-out bearing and have some more fun with the car.
Old Aug 24, 2003 | 10:09 PM
Onyx Z's Avatar
The noise also occurs in midshift and only when in gear while moving. Even though it's not very loud, it sounds nasty.
Ryan
Old Aug 25, 2003 | 10:40 PM
Onyx Z's Avatar
It's not like the loud grinding you hear when you don't push the clutch in all the way. It's a different type of grind, a quiter, more muffled sound.
Ryan
Old Aug 26, 2003 | 07:55 AM
KRAZY K 2000 TA's Avatar
Also when u said u put it in gear while moving u coulnt put it back in gear thats probably because the pilot bearing was still turning the input shaft for the trans(same as clutch engaged)making it hard to return to any gear
Old Aug 28, 2003 | 12:16 PM
Onyx Z's Avatar
The clutch was disengaged and all the way to the floor. So what do you think the problem could be? The clutch?
Ryan
Onyx Z's Avatar
The clutch was disengaged and all the way to the floor. So what do you think the problem could be? The clutch? Pilot Bearing?
Ryan
Old Aug 28, 2003 | 01:03 PM
BowTieTill IDie's Avatar
Strange...sounds a lot similar to the noise I have been hearing. Only makes the slight humm-grind noise while moving in gear. Mine only has 23,000 miles on it though!
Old Aug 28, 2003 | 11:42 PM
Onyx Z's Avatar
Sounds close what I'm hearing. When your clutch is about halfway down, do you hear a grinding like noise? Not like the loud, obnoxius grind like missing a geare, but a quieter sound.
Ryan
Old Aug 29, 2003 | 01:01 PM
Ryan
Kinda...but MUCH quieter than missing a gear. And it happens even when my clutch is pushed in all the way. Happens more while downshifting I think too.
Old Sep 4, 2003 | 11:42 AM
I have come to realize that it is worse during downshifting...it's a soft, but disgusting grind, like a bearing is out.
Old Sep 5, 2003 | 08:50 AM
1fast00ta's Avatar
I think mine makes a similar noise to what you guys are describing. It only does it when I'm sitting still and I have the clutch all the way to the floor in gear. It's not real loud or anything but it's something I can feel. I have no idea what it is but I was hoping I could find out in here.
