Vss..
Old Jul 18, 2008 | 12:25 PM
the_merv's Avatar
Veteran: Air Force
Default Vss..
I'm swapping from a 4L60E to a T56..is the VSS in the Auto the same as the T56..I don't have them both infront of me to check it..
Old Jul 18, 2008 | 02:06 PM
CamaroKid89RS's Avatar
No, they're not the same. It uses a different sensor. Or at least that's for an LT1. The connector is different too.
Old Jul 18, 2008 | 03:32 PM
the_merv's Avatar
Veteran: Air Force
Both of them will be LSX Trannies..see the sig..
Old Jul 18, 2008 | 04:15 PM
jmm98LS1's Avatar
I don't know if the entire sensor is the same, but the plugs are. The VSS male plug from my A4 harness fit the M6 VSS sensor and it works fine.
Old Jul 18, 2008 | 09:15 PM
the_merv's Avatar
Veteran: Air Force
I called a friend at a Tranny Shop..pretty much everything from 1998 and up is the same..so I'm good.
