bell housing to engine block
Old Aug 22, 2008 | 07:10 PM
dannyo210's Avatar
Default bell housing to engine block
Hey guys, I was curious if any of you torque the bell housing to the engine block, or do you just tighten it by feel?
I know the torque spec for the transmission housing is 37 ft lbs, what's a good torque for the bell housing to the engine block, if it's needed?
Thanks,
Dan
Old Aug 22, 2008 | 11:06 PM
TranzAmMan's Avatar
The specs are 35 ft lbs, but i always leave the upper ones a little bit looser then the rest so I can get them back out. But not too much.
Old Aug 23, 2008 | 09:29 AM
crainholio's Avatar
Just. Amazing.
