Speedo gear...
Old Aug 24, 2008 | 01:45 PM
Bratvold's Avatar
Default Speedo gear...
Is there a special way it's suppose to go on? I see that there is a notch on the inside.
Old Aug 24, 2008 | 01:49 PM
85MikeTPI's Avatar
No. It's adaptable to other transmissions (T45, etc.) which have a dowel on the shaft, but the T56 is fully splined and the notch isn't needed/used. There's lock rings on both front and rear of the gear to keep it from sliding either way on the splines.
Old Aug 24, 2008 | 03:33 PM
Bratvold's Avatar
Cool. That's what I thought since I've never seen a post about it.
