Wiring for M6 conversion
Old Sep 2, 2003 | 06:05 PM
MXKidd's Avatar
Default Wiring for M6 conversion
I've searched and I've searched but found only one post talking about the wiring needed for an A4 car converted to T56.
I'm in the middle of my swap, ie: M6 engine harness is in, pedal assembly is in, PCM is in, hole for shifter has been cut, but now I'm stuck with the wiring part. I know some of the wires from the A4 shifter have to be routed to the clutch pedal and some have to be linked in order for the rear hatch to work. Can anyone shed some light on this? I'm tired of waiting on people that said would help but end up just bailing on me.
thanks in advance..
Old Sep 2, 2003 | 06:12 PM
Spellbound's Avatar
Default Re: Wiring for M6 conversion
Hey, if you need to look at my car for an example pm on norcal
Old Sep 2, 2003 | 06:13 PM
MXKidd's Avatar
Thanks Duane,
I'll have to take you up that..Thurs?
Old Sep 2, 2003 | 06:15 PM
Spellbound's Avatar
ok sounds good
