Huge Problem, need help!
Old Sep 6, 2003 | 12:07 PM
z289899's Avatar
Default Huge Problem, need help!
I was taking off this morning, just screwing around. I hit 2nd and let the tires go for a little bit, then came up on a car so went to 6th. When I went to downshift to 5th it wouldn't go in. Then I tried some other gears and they didn't want to go in either. Pulled over and tried to leave it and neutral, let out the clutch and it was still in gear and killed. When I put the clutch in, it's fine so I know it isn't that. I tore apart the shifter, everything looks ok as far as I can tell. Now it won't even come out of 6th gear. When I got it home I tried to put it in 6th and it stuck there and even with a whole lot of force it won't come out. Anybody have any idea what just tore up in my tranny? Any ideas would be greatly appreciated. Thanks
Old Sep 6, 2003 | 02:42 PM
770Guy's Avatar
Default Re: Huge Problem, need help!
Im no expert, but you might wanna contact someone for a new transmision, ill send ya a PM with a good place to get one.
Old Sep 7, 2003 | 12:19 PM
z289899's Avatar
who makes the strongest t-56? And what is the deal with the viper output shaft?
